Wider tires and Carbon Rotors on an RS4
Howdy Folks,
Im thinking about putting a set of 20's and Carbon Rotors/pads on my car.
How wide a tire can I run? Id like to run 275s if i can get them to fit. Anyone already done this?
Arethe Porsche rotors and pads a straight swap? It looks like it.
Thanks for the input,
Dcel
Dcel
RE: Wider tires and Carbon Rotors on an RS4
If you space out your wheels you might even be lucky to go with 305's but I could never be sure and can I ask you why you would want the 20'? I run original size tires on mine but I have nice Honda-tuner looking wheels at 17' a piece, matte black I think it looks nice.
b7misanors4,
I like the way a 20 inch wheel scales the car (makes it look smaller) and the contrast of a black wheel on a silver car.
AlsoI think the car needs more rubber on the ground. 305's would be cool, i cant see it happening.
Dcel
Dcel
ORIGINAL: DCEL
Howdy Folks,
Dcel
Howdy Folks,
Dcel
Give a Man a fish (or, in this case, an answer)
TEACH a Man TO fish (for his OWN answers)
Or, are you simply after the *bling*-factor of big, w - i - d - e w - h - e - e - l - s & something that has a Porsche-logo on it?
AWDaholic,
Wow! Did my questions somehow offend you?
I wasn’t aware thatI needed to go into a dissertation about why I wanted to make modifications.
I can however comment on your specific statements.
1) I wouldn’t call it “BLING†(I envision 24†chrome hoops on a Cutlass Supreme when I hear that term) But as I stated in the post, I do like the look of a (little) bigger, black wheel.
Even with my limited seat time, my car feels like it needs a more rubber on the ground. The 255’s seem to slide with little effort. I think 275’s would add some grip.
2) With regard to the Carbon Rotor/pads. It was simply a question. If you don’t have the answer, IT’S OK! You’re not being graded. Try to remain calm.
Interestingly enough, I used to be the Quality Manager at Wilwood Engineering (A high performance disc brake manufacturer in So-cal) and as a side thing, I fabricate custom brake applications. I’ve done Vipers, old and new Corvettes, Mustangs, Import stuff, etc. (I am still a Wilwood dealer in anyone needs parts.) As a result, I have a fairly complete understanding of the process.
So really I wasn’t looking for you to dissect the intricacies of changing to Carbon parts.
Primarily, I was looking for someone (who hasn’t had too much REDBULL) to say was “Yea, that is a common swap, the Porsche parts bolt on†or “No way! they are completely different, everything has to be custom.†Or if it hasn’t been tried, a collective “we don’t knowâ€.
For me, the best reason for changing to a Carbon rotor/pad is rotating mass. The iron rotors have no problem absorbing and shedding the heat generated by an RS4.
But the weight has a detrimental effect on acceleration. As the cars are torque challenged to begin with, removing 15-20 lbs of rotating weight will be noticeable.
But I digress.
Your response has neither given me nor taught me to fish. More correctly you have given me the bird and quite pointedly, taught me NOT to ask questions.
So that we are clear, if I want something that says “Porsche†on it. It won’t be brake part.
Jason
But I digress.
Jason
DAMN, I eHat when I open my mouf and insert my foot. On the plus side, I did step in some mayo, today, so the taste wasn't all THAT bad, FWIW.
But, phoreel-phoreel, if you got ALL THAT expereeeeince behind you, why you askin? I'd think you'd've had the resources readily available to you. By "import-stuff" I'm assuming Nipponese? I'm guessing yes, or else the "intricacies" wouldn't have been "foreign" to you.
But, since you apparently have not yet hit the google button I'll help, no, it isn't always astraight swap. Again, depending on teh donor application, you may need an adaptor bracket to rotate the attachment point the 90deg some swaps need to fit Porsche to Audi. Verstahts du? But, since you've "engineered" your own BBK's, I'm guessing fabbing up something like that would besehr bissen kuche, nein? Check mit der GutAchter, erste, mein fruende. I'd also ehat to see a pretty RS all bent around a jersey-wall due to ill-thought-out engineering.
Oh, and, as far as the "weight" goes, you'd just be swapping one set of un-sprung weight for another, going BIG on the wheels, but *you* already know that, right?
My apologies for assuming you're some teen-aged doof with more money than brains. You're obviously NOT teen-aged.
Oh, oh, oh, also, since we're both in panties-inna-bunch mode..., wider wheels, even when "spaced" appropriately, can have a deleterious effect on camber, bearing-life, and other unintended "handling" side-effects... But, you knew that, TOO, dintCha? And, you also knew that a tape measure, pencil, paper and/or a calculator would have answered all your questions...
But *I'M* wrong for assuming you dint know WTF you were talking about.
My BAD!
My BAD!
I'm brand new here today, and because of the arrogance of TEH MODERATOR, I will never come back here again............................................. .................................................. .................................................. .................................................. ................................................YO U AREA DOUSCHE BRAGGIN ***, except to readthecomments of folks who agree with me!I hope this doesn't get erased by you Mr. AWD
Rueb
Rueb
I have no problem leaving comments up. Children who feel the need to resort to name calling ARE amusing, to me, Rueb. If I'm ever in SoCal I'll swing by and point & laugh at you directly, OK?
edyt to add: It occurs to me that many of you SoCal peeoples are waaaaay toooooo sensitive. 'Samatter? Not enough hugs? Grow up. At least DCEL didn't resort to name calling. For that he is to be respected. What are you, SIX? Does Mommy KNOW you stole her lipstick to play grown up? Douschbag?!?!? I know you are, but what am I?
DCEL, if you have any genuine grief with anything I've posted, MAN UP and PM me, directly.
To the child who apparently snuck onto the interwebs without parental permission, put the candy down and back away from the pretty toy. Go to your room, NOW, and think about what you have done!
Anybody ELSE have a problem, PM me. I've been here for over two years. I'm KNOWN on these boards. I'm not hiding OR backing down from ANYBODY!
ORIGINAL: Ruebsteak
Rueb
Rueb
