WTF is this!?!?
WTF is this!?!?
Has anyone seen thing?
http://www.dyson.com/fans/
Now I own a Dyson (two actually) and will most likely never buy another type of vaccum - yes, they are that good! But a bladeless fan for $300?!?!?!
Cool technology if it works (which I'm certain it does) but at that price.... naw, I'll stick to one with blades for $40 until it breaks
But it is cool
But it is cool
It uses the natural viscosity and fluid stiction that occurs in laminar flow to draw ambient air through the opening (and further down stream, from the air volume around the moving column).
It pulls air in from the base, and pushes it out through a small opening in the ring ... which actually has a cross section like an airplane wing. The size of the slit, and it's orientation on the airfoil, force the outgoing air into laminar flow. This in turn allows the flow to accelerate down the back side of the airfoil ... at the low reynolds numbers this system will operate at, the viscous forces will dominate the flow. Causing the laminar jet to slowly accelerate a column of air.
Their explanation video is actually pretty good ... http://www.dyson.com/technology/airm...asp#HowItWorks
