what are the advantages of a vertical sliding window?
Hi! This type of windows has the ability not only to move vertically, but also, if necessary, tilt to a horizontal position, as well as completely remove from the opening, which gives another advantage in their operation and increases the possibilities of design solutions. By the way, I bought vertical sliding window on prestigeplus and am completely satisfied with the services provided to me
Despite sliding windows offering a lot of advantages compared to conventional ones, they require a stronger frame and lintel to be reliable. I recommend using steel lintels for this purpose, that you can see a great selection of on https://www.mgnbm.co.uk/building-pro...steel-lintels/ in case you're thinking about replacing your windows with sliding ones. If you're planning to do this for a lot of your windows, this shop is the perfect choice for getting quality lintels at a reasonable price.
