Recomend an amp to me!
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
About to run a 10" Alpine type s sub and im pretty sure that i just need a 2 channel amp to hook it up with the rear speakers.. Can someone recomend a cheap amp that will be at least a semi quality amp?? Thanks.
I use a Class D mono amp to power my sub (see advice below copied from Crutchfield - follow this link to get to their site and follow the links to additional information). You can't go wrong if you pick a reputable name brand (my Sony amp works great).
Subwoofers — A mono amplifier makes a great choice for powering subwoofers. They're specifically designed for low-frequency reproduction, with built-in bass boost and low-pass filters. Class D mono amps are often a good choice — they draw less current, produce less heat, and are more efficient than conventional amp designs. You can use a 2-channel amp for powering two subs, or bridge the amp to single channel operation for a single woofer. Likewise, a 4-channel amp can be bridged to 2-channel mode to power a pair of subs. How much power you need depends on the subwoofer(s) you'll be using, but figure on at least 150-200 watts per sub for 10" or 12" subwoofers.
ORIGINAL: VitaminB6
check out your sub model# on alpine's site and see what the optimum wattage is...also, depending on whether the sub is a single voice coil or dual voice coil, and also depending on the ohm rating for each coil, the amp you need could range from a 200w to an 1800w
http://www.crutchfield.com/S-vymgqs0...0&I=500SWS1042
^^This is the sub i got (but for $80 shipped.)
I guess it has dual voice coils (what does that mean?)
Do you think there is a suitable amp out there for less than $100 that would work well?
dude i have an amp that i've been wanting to sell.. its a JL Audi 300.2 amp.. works awesome.. i had it hooked up to a 12" Infinity sub..
i was supposed to sell it to a guy local here.. but i got lazy and never emailed him back..![Frown](https://www.audiforums.com/forum/images/smilies/frown.gif)
here are some pics.. do some research on it if you want..
![](http://www.sirenonline.net/images/ebay/amp1.jpg)
![](http://www.sirenonline.net/images/ebay/amp2.jpg)
![](http://www.sirenonline.net/images/ebay/amp3.jpg)
![](http://www.sirenonline.net/images/ebay/amp4.jpg)
