ok im dumb its late and I need some help
trying to post some pics of my ride and my rims for sale tried in the test area but when i used the url they gave me for the forum through image shake it wouldnt work what am i doing wrong
RE: ok im dumb its late and I need some help
Easiest way to do it is to simply right click the full-size photo where ever you have it hosted, select "properties" and copy the address. Then paste it into the image tags whick look like this . . .
[IMG]*********[/IMG]
Replace the stars with whatever the address is.
For example, my sig pic is hosted with www.putfile.com so the address of it is "http://f5.putfile.com/6/16223571655.jpg" With the image tags wrapped around that, it will display properly. Oftentimes, the bulletin board code that they give you includes code not supported by certain boards, such as thumbnail preview. It's easiest to just do it the way I described, then you know it will work everytime (unless it doesn't).
im sure if i was sober i would be able to do it, but right now im not so sober.. Ill just post the links and make you guys click on them to see the pics.. maybe if im awake later when im at work and my hangover is not so bad ill try that, but all i got was ... BLAH BLAH BLAH cant function right now... im surprised i can even type and spell.. but thanks for the info...
