NEW! 2.7 tt upgrade...492wHP/510wTq I want it!!!
I found it on Autospeeds website
http://www.autospeedperformance.com/
Check out the dyno read and other info and clips....they're running up to 28lbs/1.9bar!!!!!!
ASP GT25R Turbo Kit
Consisting of the following components:
[2] Garrett Honeywell GT25R Turbochargers
• Compressors Machined for Charge Reference Lines
• Turbine Housings Machined and Tapped
• Turbine Housings Modified to facilitate External
Wastegates and WG cavity plugged and welded to help spool.
• Pre-Assembled with all Lines & Indexed for Easy Installation
[1] ASP Stainless Steel Tubular Exhaust Manifolds (set)
[1] ASP HighFlow Downpipes with 200cpi Metallic Catalytic Converters (set)
[2] TialSport 38mm External Wastegates
[2] Split Wastegate Tubing, Flanges and Hardware
[2] Stainless Braided Teflon Lined Oil Feed Lines with AN Fittings and Washers
[2] Stainless Braided Teflon Lined Charge Reference Lines with Banjo Fittings and Washers
[2] Stainless Braided Teflon Lined Coolant Return Lines with AN Fittings, Banjos and Washers
[1] OEM Modified Coolant Feed Line
[4] Turbo Inlet Tubes, Silicon and Clamps
[2] Turbo Outlet Tubes, Silicon and Clamps
[1] Hose Fitting Package for Wastegates, Charge Reference, Coolant Return Hoses and Clamps.
[2] Head Gaskets
[1] High Strength Head Bolt Kit
[1] ASP CNC 85mm MAF Housing (Runs Hitachi MAF Sensor with no Flow Straightener Needed)
[6] 440cc Fuel Injectors on OEM 4 Bar Fuel Pressure Regulator
[4] Fuel Rail Spacers and Hardware
[1] High Flow 255l/hr Fuel Pump
[6] Bosch Spark Plugs
[1] ASP Phenolic Spacers (set)
[1] Gasket Kit for Manifolds, Downpipes and Phenolic Spacers
[1] Motronic Software Tuning – Standard Offering
• 93 Octane Street Program
• Approx. 28psi [1.9bar] Maximum Boost Request to 24psi [1.65] by Redline
• Approx. 15 Degrees Timing Advance by Redline
• Air/Fuel Ratio (AFR) Set to 11.0:1 at Full Load
• Rev Limiter set to 7,100rpm, Speed Limiter Removed
• Fuel Consumption Gauge Calibrated to read Accurately
• Catalyst Plausibility Disabled to Eliminate Check Engine Light (CEL) for Test Pipes
• Lower Boost and/or Octane Specification Available at no additional Charge
Call for Ordering Information
$12,950 MSRP
[IMG]local://upfiles/7261/FF5C8C54960B415BB06C3784874B9A78.jpg[/IMG]
ASP GT25R Turbo Kit
[2] Head Gaskets
$12,950 MSRP
RE: NEW! 2.7 tt upgrade...492wHP/510wTq I want it!!!
ORIGINAL: Redgoat
holy crap.. now that is some power!!! Wonder what it is at the crank?
It tells you in the video clip with the dyno run...630crank hp and 653crank tq
ORIGINAL: 99a4audi
OMG thats insane, thats faster then an RS6
