is it more fuel efficent to run your car on a half tank
like if everytime you filled up it was only to the half way mark with the ocanional time when you filled it up completly. also is it true if you pump slower u get more gas or something like that.
RE: is it more fuel efficent to run your car on a half tank
never heard the half a tank one but I have heard if you pump slower you get more gas and fill up in the morning when it's cooler because less gas is in gas form and you'll get more gas too.
no, its better if you fill up once u reach half tank and yes its better if you pump slow. This means that youll get more liquid than gas fumes in the tank.I have a email with a bunch of these techniques and info i'll try to post it up if i find it.
https://www.audiforums.com/m_901412/.../tm.htm#901412
I just created a thread with the email i got with tips on pumping gas. Check it out
I don't know about the fill up your tank once you get to half way method but I am aware of the fact that the more unecessary weight you have in your vehicle, the more energy it will cost to accelerate and displace it around town.
The way I see it, I neverbuy more than half a tank of gas and I don't replace it until the gas light is on.
Why do I want to lug around an extra 6-7 gallons of gasoline with me in the car?Even though it weighs alot less than water, it is still sloshing around in there.
Half a tank would be more efficient because you'e carrying less weight around, and fuel is just dead weight. However, since your tank isnt baffled, its not worth it because the fuel you have will evaporate more quickly.
ORIGINAL: WeezyTT
If you keep refilling at half a tank then you're just wasting money from that half that you never use, and nowadays thats about 35 bucks
ORIGINAL: audi_n00b
That makes no sense at all. If you fill up at half a tank then you're only putting $35 in to begin with instead of $70.
ORIGINAL: WeezyTT
