how do u set up a LAN on a pc?
Old 01-24-2007, 02:01 AM
TeeterTawter's Avatar
Default how do u set up a LAN on a pc?
i am having problems setting up a local area network on the pcs in my house. lol we wanna play the new rainbox 6 vegas but dont know how to setup a LAN. if someone can help it would be great... thanks,
Old 01-24-2007, 02:07 AM
onepoint8tee's Avatar
Default RE: how do u set up a LAN on a pc?
How are your computers set up? Are you trying to do it wirelessly? Just hook up 2 computers together physicaly?
What operating system? There is a LAN/WLAN setup wizard that should do most of the work for you.
Old 01-24-2007, 02:16 AM
AWDaholic's Avatar
Senior Administrator
for hard-wired they all have to have different IP's. Like 000.000.000.001/000.000.000.002/000.000.000.003, and so on. Same gateway, same subnet, different IP
Old 01-24-2007, 02:18 AM
its all hard wired, my setup is from the cable modem to the router, thenrg45 ethernet risers to the pcs. the operating systems are windows xp.
Old 01-24-2007, 03:39 AM
Dj Spiel's Avatar
http://www-128.ibm.com/developerwork...ary/l-lan.html
http://www.pcmech.com/show//129/
GOOGLE IS URFRIEND
also--might wanna look into "DHCP" for ur router
Old 01-24-2007, 05:03 PM
AudiSpeed28's Avatar
If you're using a router, all you should have to do is plug the other computers into the ethernet ports of the router... the router should be set up as DHCP already and automatically assign LAN IP addresses... you should really look at the instructions that came with your router. good luck!
Old 01-24-2007, 05:13 PM
badassb5's Avatar
ORIGINAL: AudiSpeed28
^^^ That's what you want to do. Make sure everthing is setup using DHCP and you should be good to go
Old 01-24-2007, 05:14 PM
something to do with HTTP setting and it sets its self up
Old 01-25-2007, 07:03 PM
badassb5, that is one of the most ridiculous, yet down right hysterical sig clips i have ever seen... props
Old 01-25-2007, 11:15 PM
Dj Spiel's Avatar
yeah it is hilarious
