Getting ready to epoxy my garage floor. Any suggestions\advice ?
I am getting ready to epoxy my garage floor, and I have found out that this is a bigger job than I had anticipated that includes prepping, basecoat, color flakes and top coat and is much more expensive than I had thought it would be.
With that being said, I want to do this right and I want a good quality product. I am thinking about buying through www.originalcolorchips.com, and I want a red basecoat with black and white flecks, similar to this: www.originalcolorchips.com/garage_flooring_colors.html (Tile Red Basecoat / Black Marble Blend). I have a two car garage.
My question is has anyone here done this can can they share any pointers or advice before I start this project?
Thanks!
RE: Getting ready to epoxy my garage floor. Any suggestions\advice ?
^^ should start a "Pal's Projects" thread.
no advise other that to follow what the product says to do, but take pics as you go along for a before and after. might inspire others.
ORIGINAL: a6sheriff
Make sure you evenly spread the flakes, that can really make it look bad if its clumped at all[:@]
I did my 1-1/2 car garage when I bought my house. I used Quikrete - gray with blue, white, and black chips. It took 2kits($60 for each gallon kit at Lowes),andI even had enough left over to do themy back steps - which I didn't even prep, b/c I didn't think I'd have enough left over.
You need a warm weekend, move everything out of the garage for a few days.
Sweep it, then hose it out.
Scrub the whole floor with the acid and water mixed in a watering can.
Use a scrub brush with a broom handle, gloves,and safety googles.
Rinse it out with the hose.
Squeege the floor and let it dry good overnight.
Next day get out the paint roller - use the broom handle attachment.
Mix up one batch of epoxy - I think you have to stir it, wait 20 minutes, then re-stir it.
Cut in around the edges with a big paint brush.
Then start in the back, and work your way out towards an exit - gargage door.
Roll out 3'x3' or 4'x4' sections at a timeand sprinkle the chips kind of like how you spread grass seed.
You have to sprinkle chips each section as you go, or else they won't stick.
Let it dry 24 hrs before you can walk on it, and don't park your car or put anything heavy on the floor for 5 days.
No clear coat needed.
The red is just bad taste in my opinion. Do a grey or tan, and the house will have much more resale appeal if you ever move.
Supplies and everything shouldn't cost more than $140. I don't know what that site charges, but Lowes or Home Depot has it for less probably. Don't get hung up on the clear coat gimmick, it's only a garage floor. Anybody can do this. Good floor preparation is key. Also, if your garage floor is cracked, fix/fill any cracks in the concrete first at least a week before you plan to do this.
toohotpnoy21
04-04-2013 08:13 AM
EndangeredBeatz
09-13-2004 03:16 AM
