Answer a question & Ask any question?
RE: Answer a question & Ask any question?
A. yes, and Ironically enough some of my friends are in a D-league intramural hockey league here at school and the happen to have a game tonight, so it might just happen.
Q.did you do any intramural sports in college/ be a college athlete?
The blue color of the sky is due to Rayleigh scattering. As light moves through the atmosphere, most of the longer wavelengths pass straight through. Little of the red, orange and yellow light is affected by the air. However, much of the shorter wavelength light is absorbed by the gas molecules. The absorbed blue light is then radiated in different directions. It gets scattered all around the sky. Whichever direction you look, some of this scattered blue light reaches you. Since you see the blue light from everywhere overhead, the sky looks blue.
Do you still know how to do the Macarena
A: shorter wavelength of blue light causes it to scatter more than all the other colors and your eye perceives it as blue. i actually just learned that in class yesterday
Q: why is the sunset red?
As the sun begins to set, the light must travel farther through the atmosphere before it gets to you. More of the light is reflected and scattered. As less reaches you directly, the sun appears less bright. The color of the sun itself appears to change, first to orange and then to red. This is because even more of the short wavelength blues and greens are now scattered. Only the longer wavelengths are left in the direct beam that reaches your eyes. The sky around the setting sun may take on many colors. The most spectacular shows occur when the air contains many small particles of dust or water. These particles reflect light in all directions. Then, as some of the light heads towards you, different amounts of the shorter wavelength colors are scattered out. You see the longer wavelengths, and the sky appears red, pink or orange.
For any more sky color questions: http://www.sciencemadesimple.com/sky_blue.html
Why does it snow onlynow... when my car is in the body shop?
