activate phone
Good afternoon. Your question can be resolved literally within 5 minutes, but if you know the instructions in detail. You can search the internet, but it is better to refer to the site https://macpaw.com/how-to/set-up-new-iphone Which I advise you. On this site you can understand in detail the question of how to activate your phone. Congratulations on your purchase and good luck.
Well, I can only congratulate you on acquiring a very good phone. It turns out that you are asked to activate and tether the Icloud on your phone, which is a common procedure when you turn on a new phone. Also after activating the phone, I advise you to check all iPhone functions, so that it does not turn out that the phone for example can not call or send a message. If I were you, I would do that, check the speakers, the Internet, and whether everything works. And I would also install the program from https://www.mightycall.com/, to check how it works. I just work with VoIP numbers and it is important to me that the phone can stably run this program and function.
