1080i vs 1080p
Old 11-17-2007, 01:38 PM
PandaXpress's Avatar
Default 1080i vs 1080p
what is better 1080i or 1080p
my co worker is gonna buy a new HDTV and we dont know which one to get
Old 11-17-2007, 01:42 PM
MrFlippant's Avatar
Default RE: 1080i vs 1080p
By most accounts, 1080i is basically indistinguishable from 720p. 1080p will have the smoothest motion and sharpest resolution.
Old 11-17-2007, 02:10 PM
ocadam's Avatar
ORIGINAL: MrFlippant
+1 1080p is the best. but if you get a 1080i 720p TV it will be just fine since TV only broadcasts in 1080i so the only need for 1080p is for BR, HD and gaming. 720 looks really good for gaming. Also LCD is WAY better than Plasma! and DLP is oldschool.
Old 11-17-2007, 02:32 PM
.clipse's Avatar
SoCal Crew Member
actually plasma is more for vibrant colors and lcd for it's sharp images and pictures
Old 11-17-2007, 02:35 PM
MrFlippant's Avatar
And DLP is sharp, AND vibrant, AND great contrast, AND deep blacks! Hooray!
Old 11-17-2007, 02:39 PM
CLX's Avatar
CLX
CLX is offline
Zombie Defense Force
480i uses the least amount of energy! Save the environment! Stop global warming!
Old 11-17-2007, 03:03 PM
which one is better for sports and movies
Old 11-17-2007, 03:06 PM
MrFlippant's Avatar
For movies, I'd go with a 1080p display so that you can make full use of a Blu-Ray or HD-DVD player if you get one down the line, which would be a good idea.
Old 11-17-2007, 03:27 PM
Audi_Skydiver's Avatar
Basically the difference between i and p is how each one draws the frame on the screen. Here is an example:
"i" stands for interlaced. It means when the TV is drawing the frame on the screen it is drawing every other line or pixel at a time for the first frame and then fills it in with the second frame. It looks like this:
Top is Progressive, Bottom is Interlaced.
So as you can see it doesn't create a square box. It has jagged edges which causes motion blur on anything fast moving. In HD it is more noticeable than in SD (Standard Definition).
Now "p" stands for Progressive scan. It basically shows the entire frame on-screen at one time. Like this:
As you can see the progressive frame shows a clear square giving you a much better looking picture.
Hope this helps!
Josh
Old 11-17-2007, 03:37 PM
ocadam's Avatar
LCD FTW!!! they dont glare in light!
