Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
will this fit?
Old 10-25-2010, 04:01 PM
leximus26's Avatar
Default will this fit?
http://http://cgi.ebay.com/ebaymotor...Q5fAccessories
Will this fit on my audi a4 tq 1997 mod? and what more will i need to get more power out if my audi?pretty new beginner on this field so any answer will be great! best regards Alex
Old 01-07-2011, 09:47 AM
vtraudt's Avatar
Link doesn't work (at least not for me).
What are you looking at?
Old 01-07-2011, 10:58 AM
turbo kraut's Avatar
Tech Guru
http://cgi.ebay.com/ebaymotors/98-01...#ht_5490wt_939
this is not a recommended mod for us.... a good fmic should cost that much, or a good turbo(new) should be at least that price or double, but..... don't do it
Old 01-07-2011, 11:25 AM
vtraudt's Avatar
Don't do it!!!
I went that route (I call it Chinese ebay turbo). I bought just the turbo (nice and shiny!), which was $250 (minus $1.80 I got from the junkyard for the aluminum) down the drain.
Those turbos are USELESS.
Get a quality rebuilt turbo (they are virtually new, since all wear parts have been changed), or save up for a new T3/T4.
I DID go with an ebay intercooler kit ($300). It was not a perfect fit, but I got it to work ok (and vs. the $700-$1000 quoted for 'nice' FMIC kits out there, it was WELL worth it if you don't mind using the dremel on your plastic bumper and some 'fitting').
I suspect the manifold is not up to snuff either.
You don't need the gimmicks (or 'fillers' to make the deal look great) either.
Old 01-07-2011, 06:54 PM
FASTER's Avatar
Tech Slut
Ebay front mounts are worthless if youre looking to make real power. You have no idea the difference in power youd run on a dyno back to back with an ebay fmic and a real one.
Looks like a pile of scrap as vtraudt stated. Id go for a real kit and not some shoddy bs that speed daddy is selling lolz.
Old 01-07-2011, 07:37 PM
vtraudt's Avatar
Default Fmic
I disagree with your statement. I bought a $300 Godspeed kit for my 1998 1.8T. I went with a 2.75 thickness (made it WAY harder; should have stuck with the 2.5), 20x6. Per recommendation of my professional turbo shop, I went with 2.0 piping (2.5 increases lag, and won't help at all at power levels under 350 hp).
When the kit arrived, the pro had to admit that it is a lot of value (he objected strongly against the kit, since he would have hooked me up to is manufacturer source for clamps, couplers, and tubes, plus his custom bender/welder at great price). The T clamps, silicone couplers alone would have cost a fortune. The tubes all had 'rolled' ends (a bead to secure the couplers better). Biggest problem for me was the 2.75 thickness, and the grinding I had to do to the bumper plastic to make room for the intercooler and piping.
Pressure drop and heat exchanger efficiency values may be - if any - marginally worse than others (and I challenge anybody to measure/document it).
But unless you source FROM THE MANUFACTURER, you likely will get similar quality from second hand 'custom kit' resellers, who charge $750 to over $1,000 for the same stuff.
If you are concerned about a percent in performance, add 10% to the heat exchanger area (in my case, I have a whopping 10% more heat exchanger than a 2.5 thick unit, and it will certainly outperform a 3x more expansive 2.5 thick unit!).
At least to me, the $500-$700 saved PAID FOR THE ENTIRE TURBO.
As of now (1 year), I NEVER had a leak, hose come off, or else (18.5 psi boost, consistent in 30 degree and 80 degree weather).
In short:
- I have good experience with low cost Godspeed FMIC intercooler kit; I would never spent a dime more
- I have VERY bad (totally unusable) experience with ebay "Chinese Turbo"
- There are some acceptable 'tier 2' turbo manufacturers if you want to save some money off the Garretts, KKK prices (even the one from Brazil - forgot the name - is not all bad from what I have been told).
Old 01-08-2011, 12:21 AM
FASTER's Avatar
Tech Slut
You dont make anywhere near close to what I would consider real power. And the kit in question is for a t3/t04 (which is capable of real power)
Old 01-08-2011, 12:26 AM
FASTER's Avatar
Tech Slut
Adding to that, my fmic is too small for my setup. When I can swing getting a new core, I will bet my life that my power levels jump by a very significant amount to the wheels. Now If i was to slap on your fmic, I would lose an insane amount of power. You're just wrong man, plain and simple.
Old 01-08-2011, 11:51 AM
Tech Guru
beau leave the kid alone... he means well
Old 01-08-2011, 12:15 PM
FASTER's Avatar
Tech Slut
Sorry Dad...
It just annoys me that he seems to be a smart guy, but is always challenging people who are more informed about the subject.
