Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
k03-k03s change
Old 04-18-2007 | 01:08 PM
a3rullaz's Avatar
Default k03-k03s change
i want to change my k03 with k03s(k03 with k04 compressor-180hp version). Is it ok to change it without changing any other thing? or i should change somtehing else? after that which chip tuning i should apply for k03 or k03s?
Old 04-18-2007 | 03:52 PM
cincyTT's Avatar
I'm make believe
Default RE: k03-k03s change
You wont see more than a 5-10 hp gain from switching to a k03s. If you are replacing a worn out k03 with a ko3s that is fine. But you can directly swap them and be fine, the differnce is minimum. As for chip, just the regular ko3 chip will work, they wont have a ko3s chip and a k04 chip will be to much.
Old 08-21-2007 | 12:17 AM
mnsirx's Avatar
Member
will a 2001 s4 k03s fit in a 1999 a4? what i fine here in AF is that s4 has twin turbo and people say it wont fit. i am about to purchase a s4 turbo for my a4.
Old 08-21-2007 | 01:56 PM
cincyTT's Avatar
I'm make believe
You may be able to use the chra and then use you compressor and turbine covers. Not 100% sure, need to compare where the oil/coolentlines go
Subarashī Kao
10-24-2012 11:54 PM
chosos
01-27-2009 04:11 PM
Rajan147
09-18-2008 10:30 PM
mr.cAp
02-09-2008 01:59 AM
mnsirx
08-18-2007 01:40 AM
