BROKEN!!HELP PLEASE!!!!
ok i was putting my eurocode testpipe on last night and i had the stock cat all the way out and i was putting the new testpipe in and it seemed like the nuts that came with the testpipe werent fitting that great but anyways i was trying to screw the new topnut on the turbo to testpipe. and the topstud that it built into the turbo broke in half and i have no idea what to do now. someone told me to try and tap it out but i dont know if that will work but it would be nice if someone could tell me something cause i dont have a car right now and kinda sol!!! so if this has happened to you let me know what you did?
RE: BROKEN!!HELP PLEASE!!!!
In my belive, you have posted in the wrong section.
But I will help with what I can.
There are things you can do.
If the stud is showing out of the turbo, and you have the are to actually clap and turn it out, that would be awsome.
If no, and it broke as it does in all casses rigt at the matig surface, and its burried inside, then you have to tap it out, drill it out. In any case, I think it would be easy for you if you remove the turbo completly out of the car.
derZeck
02-22-2012 02:53 PM
EvanF
B7 Models
06-23-2010 04:41 AM
paintballcs
12-23-2009 08:26 AM
