Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
40v heads on a 32v block?
Old 01-04-2008 | 03:03 PM
danw's Avatar
Default 40v heads on a 32v block?
Ok, I know this isn't a forced induction question, but this seemed like the closest forum to put this question in.
What I want to do is put the 40v heads on my 32v. My car is a 97 A8 4.2q. I plan to purchase the 40v heads. I'm gonna doubt that anyone here has tackled this, but I figured I would ask anyway. I'm fairly certian the block/head gasket shapeis basically the same. Anyone know if the pattern will match up?
My goal for the car is 500hp, I plan build a mild turbo setup in addition to the heads in order to meet this goal. Shouldn't be too terribly difficult. I am thinking twin GT28r on roughly 6-7psi will get me in the neighborhood of where I want to be.
Before everyone flames me, Yes I know it's big and heavy, but I like to be different. ...and I figure with 500hp on tap it should be pretty damn fun, but still totally streetable.
Thanks in advance for comments/suggestions/ideas.
Dan
Old 01-29-2008 | 10:59 PM
BlackMamba's Avatar
Default RE: 40v heads on a 32v block?
If you mean putting on two heads from a 20 valve, they wont match up is my understanding, the porting is different.
Old 07-05-2008 | 03:41 AM
Spiffy's Avatar
Lets see, the 4.2 with four valves per cylinder uses timing belts at the front of the engine. The later 5 valves per cylinder V-8's have timing chains at the back of the engine between the block and the clutch housing. Good luck with this conversion. I think you may be urinating into a headwind.
Old 08-05-2008 | 06:02 PM
danw's Avatar
Thank you for the information... Didn't know that the newer style engine was a chain style. Good to know though. I think I will have to pursue making the stock engine stronger.
AudiTurbo
01-08-2014 11:00 PM
antolin
01-06-2012 06:13 PM
01wha4
04-01-2010 02:42 PM
jasonmd
07-18-2009 11:28 PM
quattrosedan
03-14-2006 08:34 PM
