door pannel removal
Open the door. At the top corners of the door panel, on the "side" of the panel, there are two screws (one per side). Remove them. Then inside the door pull (where you pull on the door to close it) you'll find one screw. Remove that. That screw holds the trim piece on that forms the inside of the handle. Force it down and off (it's gonna take some swearing). Once it's off, you'll uncover one final screw. Take that out and lift the panel off. Be careful not to pull it too far away from the door before disconnecting the electrical harnesses and the door latch mechanism.
