XTOOL X100 scanners news here
Good news!!! XTOOL X100 Pad tablet series adds all keys lost programming via OBD directly (free pin code) for 2015-2018 Jaguar/Land Rover Models with FK72 KVM module. It applies to X100 PAD, X100 PAD2, X100 PAD2 Pro, X100 PAD3 plus KC100/KC501, X100 PAD3 SE, X100 PAD3 SE plus KC501, etc. The aftermarket key is required. Please stay tuned!
Thanks!
Thanks!
How to program a new key for a 2014 Toyota Prius push start proximity all keys lost with xtool x100 pad (pad2/pad3) via OBD. The same procedure can be applied to Prius from year 2010 to 2018.
Select IMMO- Toyota- Key- By Vehicle- Prius- Proximity- 2010 to 2018- Reset Smart Key ecu (Smart Box)- Reste ECU (All keys lost)
Reset smart box takes about 16 minutes.
Reset smart box success
Select Program smart key after resetting
Put a new smart key to close the Start/Stop button
Program complete
Test new key
The new key can start the vehicle, remote control works as well.
Done.
Program complete
Test new key
Done.
XTOOL X100 Pad Do Odometer Correction Need Input Security Code Problem
One of our XTOOL X100 PAD customer asked us for help because his X100 Pad needs security code. When he tried to change the dash mileage and entered the odometer correction function menu, the X100 PAD screen appeared “Please input the security code”.
How to deal with this?
Xtool X100 PAD requires to enter security code ONLY when do odometer correction function for GM car models. That means other car brands and functions do not require the code to enter.
When you enter the odometer correction function menu and select the vehicle model, the key programmer will display a code. Please send the code to us (together with the correct GM model and year, i.e Chevrolet Cruze 2011 + code). Our factory will calculate the security code based on information your provided and send the code to you.
How to program Audi A3 2016 new MQB key using xtool x100 pad2, pad3 or x100 elite?
Note: Key can be generated by Keydiy ZB series remotes only.
Step 1: Generate remote with keydiy
the original key is 48 MQB
use keydiy kd-x2 and ZB-series remote to generate new key
Select option Audi- A3- Audi MQB FOLD (No KeylessGo)
generate remote successfully
the remote need to be programmed
Step 2: Program key with xtool
connect xtool x100 pad2 with vehicle via OBD port
turn on ignition switch with the original key
in x100 pad2, go to Select by model-Audi- A3/S3/RS3-> 2013/6- MQB platform
Follow 3 steps to program key
1. Read Immo data
2. Make dealer key
3. Learn key
Read immo data
then make the dealer key
input working key into kc100
make dealer key success
place a new key into kc100
Make dealer key success
Now start to learn key
insert the working key into ignition switch
switch ignition on
insert number of keys to be learned: 2
change another key if 1st key is learned successfully
learn key finished
test both keys
Done.
