windows going up and down,locking and unlocking
Old 07-11-2005 | 10:58 AM
CWil92's Avatar
Default windows going up and down,locking and unlocking
I was winderin if anyone could help me....the last few days my windows will go down by themselves and my car will lock and unlock..I am new to this forum..I have a 98 audi a6 2.8 quattro.I was hoping that someone might have had this problem and could advise me on what it is and how could I fix it....any help would be greatly appreciated..thanks
Old 07-11-2005 | 04:09 PM
audiscientist's Avatar
Default ECU
Somtimes this can happen by the button on the key FOB being pressed and held down by somthing else in your pocket it needs to be checked with VAG if there are no significant faults, if so, it is the most likly thing, the central locking system can be recoded to stop the windows rolling down and up by holding the button down on the FOB.
If there are signifacnt falts;
Sounds like the central locking ECU has melted, To do this job you will have to have access to VAG first to check the fault memory and second to code the new control unit correctly. The central locking control unit is fitted under the passenger carpet infront of the seat in a black box. You will need to take the side trims off and possibly take the seat out lift the carpet up and check if there is water under the carpet that has soacked into the ECU, if so you need to find out where the water has come from the two most likly possiblitys are the Air -con drain pipe blocked and the seal around the pollen filter leaking.
Audi scientist
((What happens if I turn this?)
TrixieGirl
05-20-2014 04:02 PM
lonzo3
03-22-2014 05:05 PM
SirDriveAlot
10-07-2007 12:00 AM
so1oonnet
02-24-2006 03:41 AM
RICHD
11-20-2005 09:45 AM
