when clutch problem, replace flywheel?
Old 06-28-2007 | 04:42 PM
nabujam's Avatar
Default when clutch problem, replace flywheel?
Hi,
As per my post a few minutes ago, I have some type of a clutch problem. The clutch has a problem engaging. Also, it is hard to get the shifter into gear.
The mechanic shop I went to suggested that they will be replacing the clutch, pressure plate and fly wheel. This will cost $1200 for parts and $800 for labour.
3questions:
1) does the flywheel have to be replaced when the clutch is gone?
2) could the flywheel be the culprit in this problem?
3) is this too expensive? (10 hours labour)?
Thanks,
NB
Old 06-28-2007 | 04:47 PM
techbod's Avatar
Default RE: when clutch problem, replace flywheel?
1/2/3 = no, its the slave cylinder
Old 06-29-2007 | 02:25 PM
nabujam's Avatar
Thanks for the input Dave. So, do I ask the mechanic whether he checked the slave, or do I go somewhere else for a second opinion?
I'm not sure about the ettiquete here.
allwheeldriven
06-09-2013 04:16 PM
96quattro2.8
03-13-2013 09:41 AM
lemhead16
08-27-2007 10:50 PM
Quick Reply: when clutch problem, replace flywheel?
