use Xtool X100 Pad2 with KC100 Adapter Program 5th IMMO for Audi A6L 2013
Today,let’s learn how to use Xtool X100 Pad2 with KC100 Adapter Program 5th IMMO for Audi A6L 2013 .
The first one key is original and the remote is working,the second one is blank to be programmed.
Guide in words step by stpe :
1. Tap “X100 pad2″on the screen.
2.Tap “VW/Audi Skoda/Seat”
3.Tap “4th/5th immobilizer system”.
4. Have two options”4th immobilizer system” and “5th immobilizer systerm”,Audi A6L 2013 is 5th immobilizer systerm.
5. It can’t indentify the VIN code because the ignition doesn’t turn on,just go to switch the ignition on.
6. 5th immobilizer system function menu.
1). Read immokey.
2). Show security data
Have 3 keys.
3). Make dealer key.
Please plug the KC100 into tablet,press(OK) to continue.
The KC100 adapter indicator turn blue means it powers on.
Put the original key into the coil of KC100 adapter.
Then put the blank key that ready to add to the coil of KC100 adapter
Writting key……
Create dealer key success.
4). Learn the key.
Turn the ignition on,click “OK”.
Read the note
Input the number of keys to match
put the blank key to the sensor area.
7. The first one learn successfully.
8. Then put the second one to learn,after learn with success,it prompts”Learning success”
9.Finish match the key
10. Tap “Return” button to exit the system.
To identify the two keys are working or not.
They are working fine.
11. Now I take one key outside of the car and leave one key in the car.
Start the engine. the first key can turn on.
12. Take the first one outside of the car,and another one in the car,start the engine,the key start turn on ok.
The remote is working.
13. Xtool X100 Pad2 with KC100 adapter successfully program 5th immo for audi A6L 2013. Thanks.
more information at https://www.cnautotool.com/blog/how-...audi-a6l-2013/
1). Read immokey.
Have 3 keys.
Writting key……
4). Learn the key.
Read the note
