TIPTRONIC PROBLEM
Old 11-29-2007, 01:39 PM
jamesfreeman86's Avatar
Default TIPTRONIC PROBLEM
I HAVE A 04 AUDI A4 3.0
WHEN PUTTING MY CAR IN TIPTRONIC MODE IS SOMETHING SUPPOSED TO CHANGE ON MY DASH? MY FRIEND THAT HAS A 01 1.8 TURBO SAID HIS DISPLAYS THE GEAR YOUR IN. BUT WITH MINE NOTHING AT ALL CHANGES. IT MADE ME KIND OF NERVOUS SO I NEVER REALLY TRIED TO USE IT.. ANY IDEAS ANYONE??
Old 11-29-2007, 02:30 PM
nemohm's Avatar
Default RE: TIPTRONIC PROBLEM
What does your owners manual say?
Look at the photos on the display .
Old 12-01-2007, 02:43 PM
dankhound's Avatar
The part or the instrument cluster where it displays p,r,n,d should change to numbers for the gear you are in. Check to see if the tip even works. You wont hurt anything. My guess would be that is wont work in which case you probably have a bad switch unit under the shifter. Usually there is a fault in the trans control module if there is a problem with the tiptronic.
Old 12-03-2007, 12:45 AM
YAH NOTHING HAPPENS IN TIP MODE. NOTHING CHANGES ON DISPLAY NOR DO GEARS SHIFT. HOW MUCH AM I LOOKING AT TO FIX THIS AT THE DEALER?? ANY CLUE?
Old 12-03-2007, 01:37 PM
AZAudiA6Q's Avatar
Same thing happens to me. I switch into TIP but am unable to shift gears and the display doesn't change at all.
Old 12-03-2007, 11:03 PM
dankhound's Avatar
It really depends. Sometimes there is a magent that falls out of the tiptronic switch in which case you must just put the magnet back in place. Worst case scenerio is that the swihtch was damage by eithr something spilled on it or some other electrical failure. In that case you would need a new switch assembly under the shifter. Not to much labor but the part will probablly run at least a couple hundrend bucks.
Old 12-11-2007, 12:33 PM
Nothing has been spilled on it. How would I get to the "magnet"
Old 02-27-2008, 12:57 PM
cretinx's Avatar
same thing is happening to me
this is the most unreliable car I have ever owned, by far. Good thing I got it free.
Old 04-08-2008, 06:12 PM
Haze's Avatar
same happens when no lights no gear changes but auto remains. quote to fix $4800 to change tcm the computer servo. i bought a dvd manual and will check the selector magnets etc. my vag fault check came up check wiring so this is the next step
Old 04-09-2008, 03:29 PM
This is fixed. Its a 50 dollar magnet piece.
DONE!
Quick Reply: TIPTRONIC PROBLEM
