Sputtering at low acceleration
Old 01-08-2014 | 01:17 AM
Insomnia702's Avatar
Default Sputtering at low acceleration
Hi fellow audi drivers. Im stumped and running out of car funding. Ive replaced spark plugs, wires, maf sensor, k&n air filter, all O2 sensors, cham shaft sensor, timing belt, water pump, thermostat, all vacuum hoses and the evap purge solenoid. After all that the car still has a code P0507 and cant figure out why the car still has a flutter/sputtering at low acceleration. If I step on it (40%+ throttle) the car speeds up without issue. So only at low acceleration an idle does the car sputter. Any ideas, comments, advice would be greatly appreciated. I have a 01 A4 2.8 v6 fwd B5 model. Thank you again for the help
Old 01-11-2014 | 11:16 PM
ImTheDevil's Avatar
Look up the procedure for a throttle adaptation and try it out - it may help the problem.
Old 01-17-2014 | 10:30 PM
Thats what I was going to look at now that I replaced all my vacuum lines and crankcase breather system hoses. Those were shot! Such a poor design from such a reputable manufacturer. Ill google the throttle adjustment next, if u have a link handy post it. It would be appreciated and thanks for the prior advice
rmr1499
07-20-2014 04:00 PM
arc11
09-12-2011 01:32 AM
slvrA4qm
03-21-2008 10:11 AM
vv15629
10-28-2007 12:29 AM
neur0tic
05-26-2007 09:45 PM
