Soft Brakes after break in
Old 06-25-2008 | 08:46 PM
LaTrang's Avatar
Default Soft Brakes after break in
I have a 2001 A6 2.7T. I changed the brakes about 3K ago. They are still squeaking and very soft. It has the Lucas-Girling brakes, and I used OEM replacements rotors and pads. I have also used a small amount of brake grease on the back sides. The car brakes ok, but I know it should be breaking a lot better. Any thoughts?
Thanks
Old 06-27-2008 | 11:22 PM
ImTheDevil's Avatar
Default RE: Soft Brakes after break in
How's your fluid level? When installing new brake pads, you have to compress the pistons in the calipers so that the new pads (which are presumably a lot thicker than the old, worn pads) can clear the rotor. Most of the time you need to undo the reservoir cap underhood so that the pistons compress more easily. It's possible that either you pushed some fluid out of the reservoir, and you're now low on brake fluid, or that you somehow got some air in the lines, which can be bled out. Check your fluid level first and top it off if needed - that makes a big difference if you're low. If not, it's worth it to bleed the brakes or have them bled - if you have air in the lines, you'll definitely lose braking feel.
ChristopherPovey
09-16-2013 11:38 AM
Audiman11
06-30-2010 01:06 PM
Interceptor
03-09-2010 11:00 PM
Pavement
10-08-2008 11:36 PM
Supaant06
01-31-2008 05:14 PM
Quick Reply: Soft Brakes after break in
