Side markers.
Old 11-23-2005 | 03:46 PM
bigdog's Avatar
Default Side markers.
I have a 1999 A8 and was wondering if any one has changed lamps on the side markers. No info in owners manual. Also interested in finding out how to turn off OIL SERVICE light. I changed the oil myself and my manual only says the dealer will switch it off when serviced.
Thanks!
Old 11-23-2005 | 04:21 PM
techbod's Avatar
Default RE: Side markers.
the side repeater lenses just twist off, service oil light needs a reset tool
Old 11-23-2005 | 04:30 PM
techbod's Avatar
UK is cheapest for the tool
http://images.google.co.uk/imgres?im...l%3Den%26lr%3D
wow your are expensive
http://images.google.co.uk/images?q=...set+tool&hl=en
I would be looking for draper tools if I were you
Old 11-23-2005 | 06:15 PM
sandman's Avatar
this is for a 98 a4........ just realized you have an a8, hope this helps............
as for the side markers, all you need to do is tape off the back side of it so you dont scrape the paint and push/pry with a flathead shrewdriver. see
to remove the bulb, simply pull.
and to clear the service insp just read this.
Old 11-23-2005 | 06:35 PM
techbod's Avatar
so is that book for the A8??
Old 11-23-2005 | 06:40 PM
techbod's Avatar
what flash setting did you use for that I have the fujifilm 2800zoom finepix and new to it, the flash is a problem as it whites out the picture???
Old 11-23-2005 | 10:25 PM
bigdog's Avatar
Thanks guys. I thought the side marker would pry off, but I did not want to risk breaking it. I will check the oil thing out now. Thanks again.
cmacelo121
09-18-2009 10:50 PM
Jeffla
02-24-2009 01:00 PM
moeron7
07-12-2007 02:58 PM
sdsteez
04-24-2007 06:04 AM
Philja
11-18-2004 10:37 PM
