Question about A6 C6 fusebox
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
I have a question if anyone knows,
I want to put a 3G wireless router in the car.
I want to put it right back to the fuse box. * in the front there is little space
The idea is that if I connect a minus (ground) of a screw can put + on one fuse off a shoe and it goes well,
my problem is I'd like that my router will work as long as the ignition key in on, when I pull the key out of ignition, the router will go off,
from what I saw in the luggage compartment all the fuses are working all the time.
Does anyone know how to do, or if you move it elsewhere?
I installed an A/C power plug for my XM radio to the fuse box on an accessory circuit. I can't remember which one it was but I just striped the wire back on the positive lead and stuffed it down into the non-fused side of the socket and reinserted the fuse to capture it. You would use the same method. But check some of the unused fuse sockets in the panel that you might rob power from.
