Proper sequence to bleed 01 A$ brades
Old 01-12-2008 | 01:15 PM
tampaaudi's Avatar
Default Proper sequence to bleed 01 A$ brades
I've installed new rotors and pads on my 01 A4 and now need to bleed the brake system. Can someone provide me the correct order to bleed the brakes. i.e. Left front 1st, right front 2d. ? Thanks in advance for any help.
Tampaaudi
Old 01-12-2008 | 01:32 PM
ImTheDevil's Avatar
Default RE: Proper sequence to bleed 01 A$ brades
Just think of it in terms of bleeding the calipers in order of the farthest from the master cylinder, to the closest. That way, any bubbles in the lines are gradually moved forward to the master cylinder where they can be burped out of the reservoir. Start with the passenger rear, then the driver rear, then passenger front, and finish with the driver front, and you'll be set.
Old 01-12-2008 | 05:10 PM
leftyturner's Avatar
You shouldn't have to bleed the system if all you did was change pads and rotors. However, if for some reason you unhooked a brake line then you should do it.
tomattsi
04-23-2015 01:02 PM
german_lover217
05-15-2012 05:49 PM
MingDriver
09-16-2011 01:58 PM
quatro
07-08-2008 10:47 PM
apg96
02-09-2006 04:17 AM
