P0304 and P0688 - A4 1.8T Quattro 02
hey is the p0688 gone also
my car wont start has a p0688 it had a misfire turned out a bad coil connector changed the connector went to start car and wouldnt start now has a p0688 relay 219 is good not sure whts going on???
Hi Jim, noticed you have been helping hjeff out. My car won't start. I am having the same problem but my #29 20amp fuse keeps blowing (ECM). I did the check for the relay and it checks out. My codes before I cleared them were p0420, p0300, p0302, p1103, and finally p0688. The only thing that I did was reset the throttle body by pushing down the gas pedal with the key in the on position and then turned off the key and released the gas pedal. I also did put a new ignition coil on #2 bank to see if that would clear and that is about it. Please help. Brent.
rerodriguez11
10-16-2007 04:40 PM
