oil temperature indicator turns on and off
Old 02-13-2010 | 09:42 PM
francisco's Avatar
Default oil temperature indicator turns on and off
Hello,
I have a 97 Audi quattro 1.8 turbo with 97,000 miles. The oil temperature indicator keeps turning on and off. I replaced the oil temperature with a genuine replacement. I also changed the oil and coolant but the issue continues. Does anyone have any hints as to what could be causing this?
Thanks,
Francisco
Old 02-14-2010 | 01:57 AM
Midniteoyl's Avatar
You sure its the temp and not the pressure light?
Old 02-21-2010 | 12:08 AM
francisco's Avatar
Yeah it's actually the pressure light. I changed the pressure switch and put in new oil plus a filter. The light is on while driving but it actually comes on when I come to a stop.
I took the pressure switch out and put in a pressure gauge. It's reading okay at 2k rpm although at idle it reads 10 PSI. It also currently has a tiny oil leak.
Old 02-21-2010 | 02:45 AM
Midniteoyl's Avatar
Well.. being an older 1.8 I would start looking into the "sludge" problem. Do a search on the board and google. You'll find tons of info.
http://members.***.net/ambox/audi_sludge/
http://www.quattro123.com/A4TurboEng...yExtension.htm
quattros4life03
09-06-2008 05:21 PM
Conte4ever
11-06-2007 06:49 PM
getabc
08-20-2007 10:45 AM
rennie
07-25-2006 08:14 AM
A4_Spooler
09-25-2005 08:46 PM
