Not Spooling?
Not Spooling?
i have a 2k TT Quat 180hp, normally the turbo with spool up around 3k-ish. recently that hasnt been the case, im getting no odd noises so i doubt it is the turbo itself, and no vacuum leaks, but sometimes the car will boost intermittantly and also at much higher rpms. can this be a N75? or is it something else. if anyone might know help would be appreciated. thanks
RE: Not Spooling?
ORIGINAL: Altt180
i havent ran a VAG cause its not throwing me a light. i think ill grab me a new n75 and start from there, just reading through similar problems on a search alot of fingers point to n75.
Even if the CEL isn't on, there can be stored codes. It can be something as simple as a pinched line on the N75, or a faulty connection.
