NO POWER (ELECTRICAL)
I HAVE A 2000 AUDI A4 1.8TQ. I PUT A BATTERY IN IT THAT WAS A TOO BIG FOR IT AND BOTH THA CONNECTORS TOUCHED HOOD AND NOW I HAVE NO POWER TO THE CAR. I TRIED TO JUMP START IT AND GOT NOTHING SO I DONT THINK ITS THA BATTERY. I FIGURE IT MUST HAVE BLOWN A FUSE. I FOUND THA FUSES UNDER THA DASHBOARD BUT I CAN'T FIGURE OUT WHICH IS WHICH. NEED HELP PLEASE!!!
RE: NO POWER (ELECTRICAL)
THANKS FOR UR HELP. IS THERE ANYTHING I CAN TRY TO LOOK FOR AS AN INDICATION OF THIS?
I ALSO WANTED TO SEE IF ANYONE HAS LIKE A DIAGRAM OR OR SOMETHING LIKE THAT SO I CAN CHECK THA BIGGER FUSES CUZ I WANNA MAKE SURE ITS NOT THE IGNITION FUSE.
Well look to see if the metal is broken, otherwise you can pull them and use a test light (lights up when theres a connection) or multimeter with resistance values (0 if its good 1 if its bad).
