Need help!!! P0300 p0301 p0302 p0303 p0304
Hi all. I've been having a problem with my 2000 a4 1.8t quattro. From what i can tell its in limp mode right now. When i scanned it, it came back with p0300, p0301, p0302, p0303 and p0304. So i replaced tha spark plugs and ignition coils and still the problem continues. Right now the car is stuttering pretty bad and at the most will only stutter its way up to about 45-50 mph. I can't figure out what to do. Any suggestions???
Thanks and ur help will be greatly appreciated.
my car is a newer 2000 so tha ignition control unit isn't on t
op of tha intake box do u know if they eliminated it or just moved it n if so where to?
I'm going to check the compression in a bit but if tha copression was off it wouldn't start right?
I'd rather not take it to a shop is there any way i can check for vac leaks on my own?
The spark plug i got through audi so they're the right onces.
Light the incense (just one) and when it is burning well to create smoke, then place near any vacuum lines (the motor needs to be running). If you see the smoke being sucked into any hoses, then there is a vacuum leak there. Good luck.
oh ok thanks i'll make sure to try that just been really busy at work but do u think a vaccume leak would cause the cylinders to misfire???
i got a new set of spark plugs and the problem continues. anything else it could be?????
thanks n i appreciate ur help.
