more oil related questions. whats your temps, oil and stuff
Old 07-30-2004, 10:40 AM
1.8t20v's Avatar
Default more oil related questions. whats your temps, oil and stuff
There was a post about what kind of oil to use a few days ago. I am wanted to know what everybody uses for their oil, what the engine oil temps are and the outside temps. I wanted to see if there is a difference with the cars and the type of oil using.
I use
Amsoil 0-30w
outside temp 75 and below engine oil temp 180-190 deg
outside temp 75-90deg and engine oil temp usually around the 200 deg range
outside temp 90 and above guessing between 215 and 220
I have never ever ever reached the 225 mark
I have an oil pressure gauge and at startup and crusing speeds it is about 65-70psi
Would like to know if everybody is similar and what kind of oil, and anything else I may be missing
Old 07-31-2004, 10:53 AM
1.8t20v's Avatar
Default RE: more oil related questions. whats your temps, oil and stuff
Anyone????
I cant be the only one that pays attention to this stuff.
Old 07-31-2004, 11:19 AM
Jestnomen's Avatar
6th Gear
mobile 1 10w-30
oil tem is almost always a hair over 200
Old 07-31-2004, 11:33 PM
ImolaS4's Avatar
2000 S4
15w-50
Ambient temps recently = 80+ degrees
Running oil temp = ~225 degrees
Old 08-02-2004, 01:01 AM
Doose's Avatar
Mobile 1 5W 30, and usually somewhere between about 185 and 200.
Old 08-12-2004, 08:59 AM
Divinity's Avatar
Is synthetic oil better?? I use Mobil 1 super syn 10w 30.
Old 08-12-2004, 11:37 AM
1.8t20v's Avatar
I think synthetics are better. I dont think there is one synthetic that is the all MIGHTY MOTOR OIL though, they are all good just filter it good and change it when needed. Most would probably agree.
I guess for that mater non-synthetics are ok just have to change them more often.
Old 08-12-2004, 12:20 PM
A4toZ's Avatar
Audi sent a letter of their approved oils, due to some owner's issues about "oil sludge"
AW link on AoA letter
Old 08-12-2004, 09:35 PM
ImolaS4's Avatar
Good post A4toZ!
Great link with good pic of oils.
If you have a slow modem, wait for the pic to load.
Old 08-14-2004, 11:06 PM
Doose's Avatar
Interesting, I'm suprised 0W 40 is the only viscosity of Mobil 1 listed. No Royal Purple, no Amsoil. I wonder how many oils they tested and failed?
Quick Reply: more oil related questions. whats your temps, oil and stuff
