Md state inspection FAILED my audi a4 1.8t rotor size.. need help
Hi there,
I just bought a new 99 audi A4 1.8 quattro
Took it to md state inspection and found that they said my rear rotor - .279 and .290
Which, they said they should be .314...
Should i listen to them and change new rotors or are .279 and .290 normal and still alive for other miles?
or Should i try other different md state inspection location?
Need your opinions...
thanks
thanks
RE: Md state inspection FAILED my Audi a4 1.8t rotor size.. need help
as a mechanic I have a cheat, the tester feels the edge of the rotor and if its high that signals break wear so if you grind that edge off the results are amazing
