Launch X431 Reset Audi A6L Service Lamp and Service Interval Set
how to use Launch X431 to reset service lamp and service interval set for Audi A6L?
And here is a collection of Audi A6 Trouble Repair.
Service Lamp Reset procedure:
1.Connect X-431, select [CAN BUS II DIAGNOSTIC CONNECTOR] connector;
2.Ignition ON;
3.Select Audi maker;
4.Select CAN bus system;
5.Access 17 Instrument cluster;;
6.Select 10 Adaptation,enter 02 channel, click OK;
7.Click “-”button to change the adaptation value into “0”, click OK;
8.Exit to end the reset.
Set Interval procedure:
2.Ignition ON;
6.Select 10 Adaptation,enter 40 channel, click OK;
7.Select “->” to enter the mileage interval for next service(e.g.: input 100 for 5000km,
100=(15000-5000)/100),click OK;
8.Exit to end the set.
Note: Before change the interval mileage, please verify that the adaptation value in each channel Number: Channel “41” is “0”,channel “42” is “150”, channel “43” is “150” and channel “44” is“365”, otherwise, please modify it as above procedure.
hope it help
2.Ignition ON;
2.Ignition ON;
hope it help
Many startups fail because they run out of money before turning a profit. It’s never a bad idea to overestimate the amount of startup capital you need, as it can be a while before the business begins to bring in sustainable revenue. Perform a break-even analysis. One way you can determine how much money you need is to perform a break-even analysis. This is an essential element of financial planning that helps business owners determine when their company, product or service will be profitable https://mlsdev.com/blog/ehr-development.
