KT200 Audi EDC15P Error Send Log File Solution
KT200 ECU Programmer, you can:
1. Read and write ECU data
2. ECU/TCU clone
3. ECU maintenance engineering
4. Chip Tuning
5. OBD2 reading
6. Read ECU maps
7. Checksum correction
8. Read and write Virtual data
9. Supports online update
Notice: The KT200 ECU Programmer requires an Internet connection.
Problem:
A friend of mine tested the first car Audi A4 1.9TDI EDC15P with KT200 and I drove it several times, it reads it, but when I type, this appears.
Error send log file
Solution:
This is very old ecu with many problems, try on bench not in car, must physical check to see if EDC15P or EDC15P + as msa15 not gong to read it over obd you have to desolder eeprom before can use obd read/write.
even galletto has problem with this ECU, one trick we learn was You must click read at write time…turn off dashboard, turn on and after second or second and a half click Write… Sometimes i tried 6 times before start write, back in day even MPPS brick this ecu too.
Mpps is if you have a bricked one , one of the only to to get them back to Life over obd2.
no dash fuse if doing on bench, also Fuse 40 if irc was for golf, he has old audi 80, again, this ecu cause many problems over years.
Just a note too unless you physically have checked ECU then do not make assumption of which it is. Old EDC15P (without +) cannot be done via OBD or bootmode. You need to solder. To identify these EDC15 ecu have 6 screws, EDC15P+ only have 4 screws, If you ecu have 018 part number, then Desolder only is option.
KT200 Ecu Programming and Chip Tuning Device
KT200 Ecu Programming device is a professional Ecu Programming device that includes many reading and writing protocols and the device allows you to do fast operations thanks to its powerful processor.
This device, that allows you to operate on both ECU (Engine control unit) and TCU (Transmission Control Unit), is a very useful device designed by professional tuners.
You can perform operations such as Chiptuning, Dpf, Egr, Adblue fault solutions, ECU cloning, TCU cloning quickly and simply.
Thanks to its useful and easy software program, it appeals to advanced users from beginner level users.
KT200 Ecu Programming and Chip Tuning Device Functions:
The device is Master version. So, files are read in “.bin” format.
The device supports Virtual Read mode. In this way, you can download files from the server.
KT200 covers cars, trucks, motorcycles, tractors and marine vehicles.
For TCU reading, you should buy additional TCU licence.
In situations like Ecu is damaged, you can reload the original file to the vehicle.
You can take automatic checksum.
The program automatically detects the vehicles and shows you which protocol you should operate with.
It is Free to Update. https://www.cnautotool.com/goods-720...rogrammer.html
You can use the device both online and offline.
Kt200 Ecu Programming and Chip Tuning Device Supported Languages;
Italian, English, Dutch, French, Spanish, Polish, Portuguese, Romanian, Czech, Turkish.
Any need please feel free with us sale@cnautotool.com, thanks
It is a good choice to use KT200 KT200
Highlights: 1. ECU maintenance, chip tuning DTC code removal of professional reading and writing equipment covering 99% of the models on the market. 2. TCU encoding and cloning functions. 3. Support OBD/BENCH/BOOT/BDM/JTAG. 4. Read and write Bosch MD1 and MG1 ECUS in Bench Modes. 5. Bosch EDC17, MED17/ME17, and SIEMENS Pcr2.1(with Pinout also unlocking possibility) read and write in Bench Mode 6. Vehicle list is constantly updated stays ahead of the industry. 7. The KT200 software allows you to forcibly write (forcible clone) without checksumming and supports forcibly reading and writing unknown ECUs with supported chip models. 8. Covering a full range of German, ECU Programmer, Japanese, American and Chinese models. 9. Support VW, Audi clone. (local operation without sending data to manufacturers).
KT200 ECU Programmer, you can: 1. Read and write ECU data 2. ECU/TCU clone 3. ECU maintenance engineering 4. Chip Tuning 5. OBD2 reading 6. Read ECU maps 7. Checksum correction 8. Read and write Virtual data 9. Supports online update
