If I remove cluster light bulb....
Old 03-03-2008 | 05:39 AM
max250's Avatar
Default If I remove cluster light bulb....
Hi! I'm new here, I'm Max by the way, from Quebec, Canada.
Now I have a little question, my car is an audi a4 b5..
I had some trouble with abs (abs light on + bizzar "electric" sound when braking + brake pedal became hard.. well very annoying) and I finally decided to just remove the abs fuse and now my car brakes perfectly and I'm happy
Now the problem is that since i took the fuse off.. the ABS light is ALWAYS on, and the E-Brake light is always flashing. Very annoying... I was thinking about removing the cluster and just remove those 2 light bulbs and that's probably what I will do, but I wonder.. Will it affect something if I remove those bulbs?
I'm a tech.. installer.. And I remember that some car will do bizzar things if you remove some cluster light blub.. as an exemple, i remember one day, someone asked me to remove the bulb of the airbag and abs lights on his honda (don't remember witch model but something year 2004 +) and as I did the job, then the check engine ligh and maintenance light went on! [:@]
I think you get my point.. so if someone knows... please tell me!
Big thx!
oh.. and sorry for the bad english, I normaly speak french I'm almost bi-lingual but not fully! as you can see
Thx again!
Max
sting3r
01-14-2012 03:02 PM
jmqmk8
11-06-2010 12:19 PM
DMB91
B7 Models
03-14-2009 10:11 PM
