How to charge Audi Q7 battery?
As easy as it should be i havenīt figured it out.So the battery ended because someone left the interior lights on.Then i could not check charging instructions from the manual because the manual is in the box which does not work because the battery is empty.
I found some instructions from internet and found out that the battery is under the drivers seat,and that i can charge it from a charging module which is in the engineroom.The problem is where to i stick the minus plug?There clearly is a plus plug under a red case but where do i put the minus plug?Or am i doing everything wrong?And what settings should i use with my charger?
Here is the charging module in the engineroom:
Tried to put the minus plug to the nut that has a - on it..:
And what settings should i use with this?:
gel or standard?
gel or standard?
I have the same problem - the battery being completely run down. I connected my battery charger in exactly the same way as in the first picture of this request for assistance, and blew to fuses on my charger.
How do I go about to charge the battery?
I would like to have some response from someone more knowledgeable, but do not expect any seeing as the original post was in 2013 and I am the first to comment Feb 2021!
