Help please
Help please
Hi all, I have a major problem with my A4 cabriolet, 3.0, V6, 2003, it turns over but will not fire up, checked all the fuses and there ok, also checked the ones near ECU and ok. It did fire up but ran irratically, I plugged my vag-com in and my missus pulled a fuse out, bottom left, 15amp, there was some kind of beeping noise, below is the reading before she pulled the fuse out and an after reading, please help, many thanks.
Chassis Type: 8H - Audi Cabrio B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 26 36 37 45 46 55 56 57 63
65 67 73 75 76 77
VIN: WAUZZZ8H83K022121 Mileage: 117690km/73129miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 H HW: 8E0 909 059
Component: 3.0L V6/5V G 0003
Coding: 0011584
Shop #: WSC 00672 785 00200
VCID: 3A702E6C0CD9
11 Faults Found:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 002 - Lower Limit Exceeded
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 002 - Lower Limit Exceeded
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 002 - Lower Limit Exceeded
17923 - Intake Manifold Valve (N156): Short to Ground
P1515 - 002 - Lower Limit Exceeded
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
P1121 - 002 - Lower Limit Exceeded
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 002 - Lower Limit Exceeded
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 002 - Lower Limit Exceeded
17548 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High
P1140 - 002 - Lower Limit Exceeded
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded
17523 - Oxygen (Lambda) Sensor Heating: B1 S1: Short to Ground
P1115 - 002 - Lower Limit Exceeded
17527 - Oxygen (Lambda) Sensor Heating Circuit: B2 S1: Short to Ground
P1119 - 002 - Lower Limit Exceeded
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 CS
Component: V30 01J 3.0l 5V RdW 3011
Coding: 00001
Shop #: WSC 00672
VCID: 7F061F78577B
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
after.......................
65 67 73 75 76 77
Coding: 0011584
VCID: 3A702E6C0CD9
11 Faults Found:
17072 - ECM Power Relay Load Circuit: (J271): Open Circuit
P0688 - 004 - No Signal/Communication
P1425 - 002 - Lower Limit Exceeded - Intermittent
P1435 - 002 - Lower Limit Exceeded - Intermittent
P1421 - 002 - Lower Limit Exceeded - Intermittent
P1515 - 002 - Lower Limit Exceeded - Intermittent
P1121 - 002 - Lower Limit Exceeded - Intermittent
P1117 - 002 - Lower Limit Exceeded - Intermittent
17953 - Throttle Valve Controller: Malfunction
P1545 - 008 - Implausible Signal - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 002 - Lower Limit Exceeded - Intermittent
Coding: 00001
Shop #: WSC 00672
VCID: 7F061F78577B
3 Faults Found:
P1857 - 35-10 - - - Intermittent
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-10 - - - Intermittent
17111 - RPM Signal from ECU: No Signal
P0727 - 35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1729
Coding: 04499
Shop #: WSC 00672
VCID: E5CA2D1055E7
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1116
Coding: 00100
Shop #: WSC 00672
VCID: 2952E120F97F
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0416
Coding: 01011
Shop #: WSC 00000
VCID: 356A3D5025C7
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 1015
Coding: 0011104
VCID: 3972316009DF
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 01141
Shop #: WSC 00000
VCID: 3E78227C10F1
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 980 JX
Component: KOMBI+WEGFAHRS. RB8 D22
Coding: 00401
Shop #: WSC 00089
VCID: 8E1832BCE0D1
WAUZZZ8H83K022121 AUZ6Z0B0414738
3 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01304 - Radio
49-00 - No Communications
01300 - Control Module for Navigation with CD-Rom (J401)
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255
Component: VSG B6 CABRIO 6185
VCID: F3EE4348EB33
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8H0 951 178
Component: Innenraumueberw. 0411
Coding: 00001
Shop #: WSC 00089
VCID: EFE64F38871B
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8H0 959 433 D
Component: Komfortgerát T3B 1210
Coding: 06827
Shop #: WSC 00089
VCID: 356A3D5025C7
Part No: 8H2959802
Component: Tőrsteuer.FS BRM 0003
Part No: 8H2959801
Component: Tőrsteuer.BF BRM 0001
Part No: 8H0959801A
Component: Tőrsteuer.HL BRM 0001
Part No: 8H0959802A
Component: Tőrsteuer.HR BRM 0001
6 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01134 - Alarm Horn (H12)
29-00 - Short to Ground
01366 - Opened Due to Crash Signal
36-10 - Open Circuit - Intermittent
00532 - Supply Voltage B+
37-10 - Faulty - Intermittent
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
sorry for the long post
65 67 73 75 76 77
Coding: 0011584
VCID: 3A702E6C0CD9
11 Faults Found:
Coding: 00001
Shop #: WSC 00672
VCID: 7F061F78577B
1 Fault Found:
P1857 - 35-00 - -
65 67 73 75 76 77
Coding: 0011584
VCID: 3A702E6C0CD9
11 Faults Found:
Coding: 00001
Shop #: WSC 00672
VCID: 7F061F78577B
3 Faults Found:
Coding: 04499
Shop #: WSC 00672
VCID: E5CA2D1055E7
Coding: 00100
Shop #: WSC 00672
VCID: 2952E120F97F
Coding: 01011
Shop #: WSC 00000
VCID: 356A3D5025C7
Coding: 0011104
VCID: 3972316009DF
Coding: 01141
Shop #: WSC 00000
VCID: 3E78227C10F1
Coding: 00401
Shop #: WSC 00089
VCID: 8E1832BCE0D1
3 Faults Found:
01304 - Radio
VCID: F3EE4348EB33
Coding: 00001
Shop #: WSC 00089
VCID: EFE64F38871B
Coding: 06827
Shop #: WSC 00089
VCID: 356A3D5025C7
Part No: 8H2959802
Part No: 8H2959801
Part No: 8H0959801A
Part No: 8H0959802A
6 Faults Found:
Thanks imthedevil
cleared all codes and re-scanned, results below, car still wont start.
Coding: 0011584
VCID: 3A702E6C0CD9
Coding: 00001
Shop #: WSC 00672
VCID: 7F061F78577B
3 Faults Found:
Coding: 04499
Shop #: WSC 00672
VCID: E5CA2D1055E7
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Coding: 00100
Shop #: WSC 00672
VCID: 2952E120F97F
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Coding: 01011
Shop #: WSC 00000
VCID: 356A3D5025C7
Coding: 0011104
VCID: 3972316009DF
Coding: 01141
Shop #: WSC 00000
VCID: 3E78227C10F1
Coding: 00401
Shop #: WSC 00089
VCID: 8E1832BCE0D1
4 Faults Found:
00668 - Supply Voltage Terminal 30
01304 - Radio
VCID: F3EE4348EB33
Coding: 00001
Shop #: WSC 00089
VCID: EFE64F38871B
Coding: 06827
Shop #: WSC 00089
VCID: 356A3D5025C7
Part No: 8H2959802
Part No: 8H2959801
Part No: 8H0959801A
Part No: 8H0959802A
8 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
00955 - Key 1
35-00 - -
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00070
Shop #: WSC 00672
VCID: 040C90943E9D
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F H11 X023
Coding: 00005
Shop #: WSC 00065
VCID: 356A3D5025C7
1 Fault Found:
07-10 - Signal too Low - Intermittent
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H11 X023
Coding: 00005
Shop #: WSC 00065
VCID: 356A3D5025C7
1 Fault Found:
Coding: 0011584
VCID: 3A702E6C0CD9
Coding: 00001
Shop #: WSC 00672
VCID: 7F061F78577B
3 Faults Found:
Coding: 04499
Shop #: WSC 00672
VCID: E5CA2D1055E7
1 Fault Found:
35-00 - -
Coding: 00100
Shop #: WSC 00672
VCID: 2952E120F97F
1 Fault Found:
Coding: 01011
Shop #: WSC 00000
VCID: 356A3D5025C7
Coding: 0011104
VCID: 3972316009DF
Coding: 01141
Shop #: WSC 00000
VCID: 3E78227C10F1
Coding: 00401
Shop #: WSC 00089
VCID: 8E1832BCE0D1
4 Faults Found:
01304 - Radio
VCID: F3EE4348EB33
Coding: 00001
Shop #: WSC 00089
VCID: EFE64F38871B
Coding: 06827
Shop #: WSC 00089
VCID: 356A3D5025C7
Part No: 8H2959802
Part No: 8H2959801
Part No: 8H0959801A
Part No: 8H0959802A
8 Faults Found:
35-00 - -
00955 - Key 1
35-00 - -
Coding: 00070
Shop #: WSC 00672
VCID: 040C90943E9D
Coding: 00005
Shop #: WSC 00065
VCID: 356A3D5025C7
1 Fault Found:
Coding: 00005
Shop #: WSC 00065
VCID: 356A3D5025C7
1 Fault Found:
Everything I see there seems to be powered up only when the key is on and turned. The "power supply voltage too low terminal 30" means less than the expected voltage is showing at terminal 30 on the ignition switch, which happens to be an output terminal. I'd replace the ignition switch and see what you get. It's a $30 part that can be installed in less than 30 minutes although you have to remove the airbag and steering wheel.
