Help with codes - CEL
RE: Help with codes - CEL
That's funny, I was going to do that last night but wasn't sure if the brake cleaner would damage it. I used a light blast of compressed air instead. I'll try the brake cleaner and test it without the filter tonight.
Thanks!
K.
Thanks!
K.
I tested the MAF sensor again without a filter at all and got the same results. I took the MAF sensor off and cleaned it with brake cleaner, replaced it and tested it and still get the same results.
I pulled off the plastic self-destructing hose/tube that goes to the valve covers to check for leaks and found none. Found no leaks anywhere else either.
I take it this means the sensor is bad?
Also, I found a few cheap used ones on ebay, but the part number is different. They're all 078 133 471, but the last letter is either A or E, mine is a C. Any idea if those will work or what that letter means? Advance Auto lists A and C for my engine.
Any thoughts would be greatly appreciated.
Kevin K.
Kevin K.
