Help ... 06 A4 Sputtering
Old 11-09-2008 | 02:37 PM
movala4's Avatar
Member
Unhappy Help ... 06 A4 Sputtering
i have no idea what going on with my car. i started the car lastnight and in started to sputter. when i step on the gas it literally feels like its going to die. the check engine light is flashing. i appreciate all the help and suggestions u guys can give me. im debating taking it to the dealer, but i am out of warranty by a few thousand miles.
Robbie
Old 11-09-2008 | 06:21 PM
CRAZYHAWK's Avatar
Don't drive with a flashing CEL. It probably is
a misfire which will overheat the CAT.
If you're under warranty, have the dealer tow
it in.
Old 11-09-2008 | 06:30 PM
movala4's Avatar
Member
any idea on how much this will run me, out of warranty. or can DIY ?
Old 11-10-2008 | 10:31 AM
CRAZYHAWK's Avatar
First replace the spark plugs. If that doesn't work,
replace the ignition coils.
Good luck.
Old 11-13-2008 | 10:07 PM
mott6904's Avatar
I would recomend replacing the spark plugs but dont just go replacing coils. Do some sort of diag. to see if its the ignitor or a coil. check for codes and that will lead you to which cylinders to start with.
Old 11-13-2008 | 10:11 PM
movala4's Avatar
Member
Talking
I appreciate the help guys ... Turns out that it was a coil. I changed all four and replaced my plugs.
Shes a happy camper again
rmr1499
07-20-2014 04:00 PM
arc11
09-12-2011 01:32 AM
BeauA4
11-29-2008 05:05 PM
cfrench
11-21-2008 11:12 PM
Jaxter
10-09-2008 09:53 PM
