Engine hesitation 3-4k rpm, suspect pullies
I just had the neuspeed pully pack (underdrive pullies) installed along with a new turbo intake hose and tuned Haldex device. Can't add more it errors out. I'll reply with more info
RE: Engine hesitation 3-4k rpm, suspect pullies
Any ideas as to what can be causing this?Intake pipe, Tuned Haldex or Pullies?Audi TT 225hp Quattro, 2002 6-speed Manual, 25k miles, Neuspeed power pack, blow off valve, short shifter, adj. control arms, 25mm sway bar, Koni’s & H&R springs.
When the car sputters sometimes it kicks on the ESP or traction control light permanently and then it handles badly. I have to turn the car off and then turn it back on to get the light to go out.
Your right, Diverter valve. I need to be more precise in my descriptions. sorry. Well, I'll get the car back to 2Bennett and let them check it out. Do you think it could be a bad Haldex? Or is this just normal for them? thanks for the advice.
BY the way I got the blue haldex from Neuspeed, installed and had dealer do an oil and filter change on it. No problems till I got the intake hose and pully pack (underdrive pullys) installed. It's going back to the shop...
