Engine Code 16395
Engine Code 16395
My engine light came on today so I ran a scan and this came back:
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 002 - Lower Limit Exceeded - Intermittent
I have not had the timing belt replaced (I have seen that question asked previously). I am looking for any possible reasons for the light, what to look at, what a possible fix could be, etc.
Thank you for your time.
I had a new tensioner put in probably last year but I think it was the serpentine tensioner. That wouldn't have anything to do with it would it?
It idles fairly smoothly but I do feel some rough spots from time to time. There is also a very light rattle over by the air filter somwhere (been there for a while and can only hear it when I have the hood open)...between that and the engine block. Wondering if that might be a cam or?
Thanks crazyhawk
Thanks crazyhawk
No the serpintine belt tensioner wouldn't have anything to do with it. Pop off the upper timing belt cover by swinging those two little hoses over the valve cover, then un-clip the cover. Try twisting the timing belt, you shouldn't be able to twist it 90*. If its loose, get timing belt and water pump done ASAP.
