Engine Code 16395
Old 08-14-2008, 07:47 PM
cwkinney's Avatar
Default Engine Code 16395
My engine light came on today so I ran a scan and this came back:
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 002 - Lower Limit Exceeded - Intermittent
I have not had the timing belt replaced (I have seen that question asked previously). I am looking for any possible reasons for the light, what to look at, what a possible fix could be, etc.
Thank you for your time.
Old 08-15-2008, 11:03 AM
CRAZYHAWK's Avatar
It could be caused by a worn timing belt tensioner.
Does it idle smoothly?
Old 08-15-2008, 12:30 PM
cwkinney's Avatar
I had a new tensioner put in probably last year but I think it was the serpentine tensioner. That wouldn't have anything to do with it would it?
It idles fairly smoothly but I do feel some rough spots from time to time. There is also a very light rattle over by the air filter somwhere (been there for a while and can only hear it when I have the hood open)...between that and the engine block. Wondering if that might be a cam or?
Thanks crazyhawk
Old 08-15-2008, 12:57 PM
auditech79's Avatar
No the serpintine belt tensioner wouldn't have anything to do with it. Pop off the upper timing belt cover by swinging those two little hoses over the valve cover, then un-clip the cover. Try twisting the timing belt, you shouldn't be able to twist it 90*. If its loose, get timing belt and water pump done ASAP.
Old 08-15-2008, 01:01 PM
cwkinney's Avatar
Where exactly is the timing belt cover? Sorry...
Old 08-15-2008, 06:16 PM
CRAZYHAWK's Avatar
In the front of the valve cover.
Old 08-19-2008, 10:43 AM
cwkinney's Avatar
Well, the belt isnt loose at all...
Anything else I can look at that possibly might point me in the right direction?
Thanks!
Old 08-19-2008, 08:35 PM
auditech79's Avatar
Well if its ok then just erase the fault code and see if it comes back. Its an intermittent code so it might just be a fluke.
Old 10-01-2008, 08:36 PM
blk340cuda's Avatar
What do you mean by an "Intermittent Code"? I just pulled the same code today and I'm trying to figure out what to do (besdies suicide)...
Old 11-30-2022, 02:55 PM
debsaa's Avatar
Engine code 16395 and P0010 obd2 code is the same for audi cars, please check protocols ISO and SAE.
Quick Reply: Engine Code 16395
