CV Joint - Good or Bad?
Old 02-10-2007 | 08:01 PM
hubturn's Avatar
Default CV Joint - Good or Bad?
Just removed the left front axle of my '95 cabriolet to replace the inner CV joint boot.You have to take the outer joint off also as part of the process soI am replacing that boot too. While cleaning the outer joint,I notice scarring on theinner cage between the ***** bearings. Also notice some discoloration of the *****, andthe races have some distinct bluish coloration as though they were overheated. Further, there was not enough grease in this joint.It operated without any noise while on the car. Itdoes not move as smoothly as the right side outer joint that Idid a boot job on last week. Question: Is thisjusta typical example of a crappyrebuiltjoint that somebody previously replaced or is this a bad joint that needs replacing now. I have my suspicions as one of the triple square bolts that connect the axle to the drive flange was rounded out. Replace it with new, buy a rebuilt , or use it as is? Markings on the joint are EMPI AU-111-3-445. Thanks.
Old 02-11-2007 | 04:20 PM
2k S4's Avatar
Default RE: CV Joint - Good or Bad?
Just throw in a rebuilt shaft. Yes, blue ***** () are not good, it shows over heating, & there should be a TON of grease in there.
Old 02-11-2007 | 04:27 PM
techbod's Avatar
without looking it could be both ways ( blue ball bearings means its working ) though with a lack of lithium grease so top it up it could be alright but then again your replacing the inner cv joint and that normally means the outer has gone bad first, change both to be comfortable
Old 08-23-2014 | 12:47 PM
dsniel.marquez's Avatar
Default cv joint for audi 1995
Hi i was wondering if someone could help me out. I have an Audi 1995 and Im looking for the cv joint. I bought one on ebay but the size is smaller and doesnt fit. The numbers on my cv joint, (the one that is broken) reads "EMPI AU-111 6 330". I tried looking on different places on the internet but have no results, could anyone tell me where can i find this part? my car is the yard for 6 months already, I would really appreciate your help, thanks
jinsojoo
11-11-2009 05:59 PM
RobK
01-28-2008 02:19 PM
specialK4
06-18-2007 10:43 PM
theycallmedalgo
01-10-2006 03:29 PM
Quick Reply: CV Joint - Good or Bad?
