Coolant wont circulate! maby thermostat???
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
well I let my buddy drivemy car (02 A4 1.8t) and what was a small coolant leak turned bad and the car heated up a bit. He clames about 3/4 of the way to the red mark. So I fixed the leak and am working on flushing out all the green coolant that was in there. I have filled the system with water and when I run the car to let the water cycle throughthe car gets up to temp and stays there but I cant get the lower cooloant hose to get warm at all. So I am thinking the thermstat wont open. Sound like it might be the problem or does the radiator do an amazing job of cooling down the water running through it???
ORIGINAL: tHe kNiGHt FaLL
i've never seen an audi w/ green coolant.
we use the pink stuff.... and when the pink and green mix it creates a gel which is known to clog coolant systems.
SAudi is right, don't mix the green stuff with the pink coolant that our audis need.
But I'm a little confused... After fixing the leak, " the car gets up to temp and stays there ", this sounds like the thermostat is workikng. When t/s fails (usually due to over-heating) they normally stay in the open position, so the engine won't over-heat, but the coolant won't get up to operating temp.
IF the temp gauge goes up to the half-way point then the t/s is working, an open t/s means the gauge won't climb much past the " C " .
What are the symptoms, do you get heat from the heat registers ?
jcd144s
01-09-2011 09:41 PM
