clutch bleeding
RE: clutch bleeding
same as doing the breaks, I prefer to use the one man type system explained in this link
http://images.google.co.uk/images?q=...n&lr=&filter=0
RE: clutch bleeding
it is mate, if you have another person with you then you can do it the same as you would the breaks but its much easier with the one man bleed kit or a bleed pipe with a none return valve in it so air cant get back into the system when you let your foot off the clutch peddle
