check engine light is on
i have a 2000 s4 and the check engine light is on. i have no idea whats wrong with the car because its running just fine. i want to bring it to the audi dealership but they are charging me 180 just for a check up. anyone got some good advice of what i should dooranyone in the bay area that can help me out with the problem or know a shop that can? thanks
RE: check engine light is on
I know auto zonehas code readers, you just need to shell out the 150 dollar deposit but you get it back when you return it...you can also check craigs list, there some guys that can check if for you for like 20 bucks.
i got the reading awhile ago and the tech told me that it was random misfiring. so i changed the spark plugs and he told me it had to be the ignition coil. the problem here is that i called audi dealer and they told me that if it was the ignition coil the engine light would be flashing. im going to go get an OBD reading again tomorrow hoping i could fix this problem.
Just go on ebay and buy yourself an obd2 scanner their only like $60 shipped, and believe me its a good investment...http://cgi.ebay.com/ebaymotors/PROFE...95130176QQrdZ1
The dealership may have told you a little bit of a story. The coil could still be the problem. The only way it flashes is if there is a type 1 misfire which is when a cylinder is dumping a lot of HC's into the exhaust After you installed the plugs did you did clear the codes right. What kind of plugs did yo uuse?
