Break Warning Symbol - HELP -
Old 02-09-2014 | 09:40 PM
esch's Avatar
Default Break Warning Symbol - HELP -
I need a wee bit of help on this one: So the brake warning symbol started to appear on my display a few days ago - This being the yellow (O) symbol and I get it when I first start the car and depress the break pedal. Happens every time.
SO, I figure I need to replace the breaks, cause they are about due. - I do this and yeah the pads are pretty warn, though I've seen worse. Either way I put on new pads and rotors, bleed the breaks and make sure the fluid is topped off. The new breaks feel great
BUT I'M STILL GETTING THE WARNING SYMBOL. Battery is strong and there seems to be no other issues.
Any ideas of what to check next?
I'm kinda at a loss.
Thanks in advance.
Old 02-10-2014 | 07:32 AM
bradtyler02's Avatar
did you reconnect the sensor wires?
possibly a defective pad...
Old 02-10-2014 | 12:26 PM
esch's Avatar
yeah, I checked the sensor connectors. Could be a faulty pad I suppose, just seems unlikely.
I was wondering if anybody knew if those sensor circuits are normally open or normally closed. I was thinking perhaps a wire was broken near the connector as they are somewhat exposed. Does anybody know?
( I was more hoping someone would say "Oh yeah, that happens all the time. You just need to ......" )
Old 02-11-2014 | 10:01 AM
I assume it's normally closed, so when the pad wears, it breaks the connection.
99'A6
02-05-2012 09:02 PM
PurpleNerple
01-20-2011 08:04 AM
Burnage 1966
07-18-2010 12:19 PM
JMBonn
B7 Models
20
04-17-2010 05:57 AM
jmmsaudi
10-05-2009 04:51 PM
Quick Reply: Break Warning Symbol - HELP -
