blinking check engine light A4 2003. HELP!!!
Old 07-03-2013, 10:50 PM
tekadionne's Avatar
Default blinking check engine light A4 2003. HELP!!!
so my car was leaking coolant and needed a new water pump. I went ahead and changed the water pump and timing belt and now the car wont start properly and the check engine light is blinking. it doesnt accelerate and the engine is shaking. Is my car done for ?? extremely nervous and not sure what the problem is . SOMEONE HELP PLEASE !
Old 07-07-2013, 07:12 AM
ImTheDevil's Avatar
The timing isn't correct, causing misfires which manifest as shaking and the blinking CEL. Do a code scan and post your codes up. My bet is you're off about two teeth - one tooth off and the car will drive a little odd. Three or four teeth off and you'll start having contact between engine internals. Two teeth off and it usually just runs like dogshit.
gamocles
06-27-2015 05:20 PM
Rn3037
05-02-2011 09:48 AM
espeed
04-05-2008 09:25 PM
mikowen10
05-03-2007 06:27 PM
joeypants
10-13-2004 05:12 AM
Quick Reply: blinking check engine light A4 2003. HELP!!!
